Calculating distance with an Axis Camera 206
I have seen a lot of people over look this in past year. Make sure you are converting it to foot and inches or whatever you desire as 1’ would be 1.2 as a double.
Sure you can, but you need to get a baseline to start from, which can be found by going through the trig for one image, or going to a field and finding it through measurements there.
Yeah, this is what I hope to do, since the error is much less than using a single target. But, if one target is not found, you will need to do the math without it, which makes things very interesting (and a whole lot of if-else, unless I find a more elegant way to do it)
