Camera code
OK after finnishing the beta test and making sure all problems were cleaned up nicely i moved on to camera tracking with no success.
Can someone give me an accurate discription of what the default code does as far as tracking the ellipse?
P.S. the reason i am asking is because Reverse engineering the code helps me understand it better.
Have you looked at the white paper? http://joule.ni.com/nidu/cds/view/p/id/1568/lang/en
Yes I have read it and it tells me what the camera is supposed to be doing but not the motors and the gyro
is the gyro indicator from the dashboard supposed to be spinning round and round?
are the motors supposed to be lining up on the target?
Only if your robot is.
Only if you hold down the joystick button (trigger I think).
