Camera error not showing up in drivers station
Our camera is not showing up in the driver station, is our code wrong?
Usually the VI with the icon “Camera Send 2 PC” in Robot Main.vi of any robot template will take care of that for you in the background, without the need to manually open the camera references.
I recommend following the troubleshooting steps in: Robot Camera Images Not Appearing in FRC Dashboard
Did you try to use the dashboard program that is automatically generated from the launch screen in LabVIEW? It should put the camera code along with a lot of other things that might be beneficial to your operation. I would start there before I go too far with what you are doing.
Yes, that didn’t work. We had to rewrite the code from scratch! Apparently you can’t reuse old code anymore without your cameras failing. We had to start a new project and copy things over. Thanks!
