Camera Feed Help
So I am trying to use a custom dashboard that I have made. The problem is that everytime I run the code and open up the custom DB I get no camera feed. Although When I run the robot with the stock DB I am able to get a video feed. Basicaly what I am trying to accomplish here is to make use of some tracking code that I wrote within the custom DB. Also just to double check, I am using port 1140 to send information to the DB from robot, and port 1130 to send information to the robot from the DB. Is this correct? Thank you in advance.
The UDP ports are correct. Is the camera wired to the bridge or the 2nd port on an 8 slot cRIO? And what are you using the UDP to tranfer?
