We may have killed our sole vision camera and I’m interested to know if anyone else has had this problem.
I am the lead programmer, and when I arrived today to do some vision tuning, I realized that the outputs from our coprocessor weren’t showing up. I traced the problem back to the fact that our camera didn’t seem to be working, and the light on the back of it (Axis M1013) wasn’t glowing when I turned off the lights in the room. Upon examining the VRM to check the connections, I realized that at some point, someone had plugged the camera power supply into the 12V 2A part of the VRM. This looked suspicious to me, and a quick google search confirmed that the camera should be running off of a 5V supply. I think the person who plugged it in just didn’t know any better/heard some false information, but I’m now very concerned that our camera has been fried.
I plugged the wires into the proper (5V 2A) ports on the VRM, and tried again, to no avail. The power cord from the VRM to the camera shows around 5V when measured with a voltmeter.
Has anyone else had this happen? What else can I test to figure out if it’s beyond hope?
Does anyone know if it’s even still possible to buy an Axis M1013? I know Axis has discontinued them, but I haven’t seen them anywhere else. However, FIRST doesn’t list any newer IP cameras as being compatible with their software.
If it’s not possible, has anyone had experience with a different IP camera (similar in size/cost/ease of use to the Axis one)? It technically doesn’t need to be compatible with the WPILIB because it’s only communicating with a Raspberry Pi over ethernet. The ability to control brightness, exposure, compression and frame size are all a must, ideally via a web interface.
One thing you may want to consider is running with a USB Camera connected to your pi. We have been using a Logitech cable and control it with http://www.linux-commands-examples.com/uvcdynctrl. We have the pi setup to run a script when it boots up so the exposure can be set (I think we have it at something like -1), and then it runs the python script.
Yes, a student fried all of our cameras in 2014 (at least three) in a space of a few minutes by applying 12V to them. He was looking for one that worked… I was so glad to see a less expensive, less easy to burn out USB camera become the new standard.
