Does anyone have a camera mount CAD for this camera that my team can borrow? Thanks!
If no one gets back to you we downloaded one off thingiverse which ended up having slightly mismatched holes we had to drill out.
Here is a document for one I made last year. You should be able to mess with it in CAD if you need to change the mounting.
the document
Wow, it’s got everything. Not experienced with Onshape, can I convert to a .STEP to use in Solidworks? Would love to save for out catalog.
Yep, just right click and select export on the part.
Thank you so much! I will check it out!
Make sure you make every part in your assembly be concentrically mated to the next drawing.
