How do I use the camera program on the basic framework for labview projects? Do I need to change ips?
The basic framework has a loop for doing camera stuff. You might want to hook up a display for debugging. Also look at the examples for color tracking, if nothing else to copy a display.
As for the electrical and IP stuff. The camera should be setup using the Camera setup tool according to the directions. Use the orange enet cable between camera and the second cRIO port.
Greg McKaskle
Thanks! I will try that, I hope they work.
