Camera Problem
We have been trying to get the camera to work with the driver station without success. The camera IP has been setup as per the instructions, using 11 for the last part of the IP, but the driver station still does not show an image. The camera is connected directly to the radio. We can see an image from the camera from the web based access, but not the driver station.
Any suggestions?
If you connect the camera to the dlink directly, the camera will not show up unless you modify the dashboard. NI has posted instructions for doing this: http://decibel.ni.com/content/docs/DOC-15144
