Camera Problems
My Axis M1014 camera works when i connect to it by plugging the cord into the computer, but not in the CRio. Why doesn’t it work? Help?
Have you configured the camera?
If you haven’t, there are instructions here:
http://wpilib.screenstepslive.com/s/3120/m/8559/l/89729-configuring-an-axis-camera
Yah,i did that, but it still didn’t work
How are you trying to use the camera? If you are trying to communicate back to the dashboard, be sure to set the camera’s IP address to 10.te.am.11. Make an FRC account with password of FRC. Turn on anonymous viewing. Then launch both the dashboard and the driver station. The DS needs to be setup with your team’s number – this is how the dashboard determines the camera IP address.
Greg McKaskle
What do you expect it to do? Telling us it “works” isn’t enough information.
Please clarify what you mean by “in the CRio”. Are you connecting the camera by an ethernet cable to the second network port of an 8-slot cRIO? Are you connecting it to one of the ports on the D-Link router? Are you doing something other than those two options?
Sorry, i’m trying to make video on the Driver Station play.
I tried configuring it both ways and it still didn’t work
I have no clue what I did, but I was messing around on the camera settings and it started working. I wish I knew what I did.
