Hello!!!
I’m trying watch the camera in the dashboard :yikes: but I can’t get an image, I’m looking in Samples proyect but the camera don’t work. Who can help me to program the camera?? for see image
Thank you!
pd:I’m working with Netbeans
Hello!!!
Thank you!
Hi,
In order to view the camera in the dashboard you must connect the camera to the Crio and the rest of the kit (I think).
If you wish to simply test the camera and view a live feed you need to follow the instructions in section 2.12 in the 2010 robot controls document (here)
In short you need to change your ip address to 192.168.0.X (x can be anything but 1 or 90, I used 99)
You then need go to 192.168.0.90 in your web browser and set up or put in the root password (default is pass)
You should then see a live feed from the camera.
Make sure you have all cables are plugged in and the camera’s LEDs are green.
Hope that helps,
timytamy
