Camera programming issues
we are trying to run two cameras on a robotic and sometimes it will recognize one camera
sometimes it wont recognize any but it will never recognize both at the same time it says on the driver station that the cameras are being seen but it doesn’t show any video we think its a programming issue but we cant seem to find anything wrong with the code so if anyone can help please
Hi, how are you creating your 2 cameras in code, and how is the driverstation showing that they are seen. Are they both usb cameras?
this is how we got it coded but we may have got somthing wrong
#include <frc/Joystick.h>
#include <frc/Spark.h>
#include <frc/TimedRobot.h>
#include <frc/drive/DifferentialDrive.h>
#include <cameraserver/CameraServer.h>
#include <wpi/raw_ostream.h>
#include <frc/PWMVictorSPX.h>
#include <frc/SpeedController.h>
#include <frc/XboxController.h>
#include <frc/Servo.h>
class Robot : public frc::TimedRobot {
frc::Spark m_leftMotor{8};
frc::Spark m_rightMotor{9};
frc::PWMVictorSPX m_blowermotor{7};
frc::PWMVictorSPX m_shouldermotor{6};
frc::Servo clawservo{5};
frc::DifferentialDrive m_robotDrive{m_leftMotor, m_rightMotor};
frc::Joystick m_stick{0};
frc::Joystick m_box{1};
public:
void RobotInit() override {
#if defined(linux)
frc::CameraServer::GetInstance()->StartAutomaticCapture();
#else
wpi::errs() << “Vision only available on Linux.\n”;
wpi::errs().flush();
#endif
void TeleopPeriodic() {
// Drive with arcade style
m_robotDrive.ArcadeDrive(m_stick.GetY(), m_stick.GetX());
clawservo.Set(0);
if(m_stick.GetRawButton(1) == true) //runs fan
                m_blowermotor.Set(1);
if(m_stick.GetRawButton(1) == false) //stops fan
                        m_blowermotor.Set(0);
if(m_box.GetRawButton(2) == true) //raises arm
                m_shouldermotor.Set(1);
if(m_box.GetRawButton(4) == true) //lowers arm
                m_shouldermotor.Set(-1);
if(m_box.GetRawButton(2) == false && m_box.GetRawButton(4) == false) //arm does nothing
                m_shouldermotor.Set(0);
#ifndef RUNNING_FRC_TESTS
int main() { return frc::StartRobot<Robot>(); }
#endif
ReplyForward
this is in c++ on visual studio
Ok so I don’t know my way around c++ super well, however it appears you are only starting 1 camera with
Try using
frc::CameraServer::GetInstance()->StartAutomaticCapture(1);
frc::CameraServer::GetInstance()->StartAutomaticCapture(2);
my mentor says your a genius and thank you
wait
thx we were testing it wireless
it fixed the problem
No problem!
