The camera we are using on our robot goes straight to the upper corner of its range of motion and just stays there instead of searching.
Using dashboard we discovered that it kept going to Pan: 30 Tilt: 254.
These values happen to be the min and max of those servos respectively.
Has anyone else had this problem or know how to fix it?
However when we put the light right in front of it, it does then track. The camera just doesn’t run its search pattern.
