Camera Tracking Target
Is anyone having trouble with their camera in terms of the camera following the target after it’s caught. We have the camera connected properly because we troubleshooted the instructions. We are using the kick-off demo for programming. Is anyone else having this problem, and is there anyone who has had this problem and overcame it?
Kevins code for easy c
Can you be more descriptive? Trouble following isn’t enough.
Also, Kevin didn’t write the 2007 code for easyC the Demo was done be Neil Rosenberg.
Make sure you download the most updated version (1/16) camera project off kevin.org .
Then build on Mplab, http://www.ifirobotics.com/rc.shtml
Transfer the .hex file to the Robot Controller through IFI loader , and you should be set,
