camera
Is there a diagram to show how the camera should be wired and hooked onto the robot. Also, is there anything else we have to do other than the configuring directions in the manual?
ROOKIE TEAM=ROOKIE QUESTIONS
Wiring for power and for control can be found on the FIRST website at:
http://www.usfirst.org/roboticsprograms/frc/content.aspx?id=10934
Specifically:
  • Power Distribution
  • Data & Control
    Follow the directions in the manual, but there are always corrections and changes to any manual. The one that’ll affect seeing the camera feedback on your Driver Station Dashboard is that the Dashboard will probably not be the correct one. You may need to run the Driver Station Update again to select uninstall, then again to install once more. This’ll fix the Dsahboard program.
ROOKIE QUESTIONS=ROOKIE ANSWERS
