Camera
When I try and run this code, I get the following exception. I am programming in Java, so why does my exception include something relating to WindRiver? I’m trying to store an image on the cRIO and then I plan to retrieve the images using FTP.
AxisCamera cam = AxisCamera.getInstance(“192.168.0.90”);
cam.getImage().write(“image.jpg”);
>>>>ERROR: The object is in an incompatible mode: No content-length token found in packet …in ReadImagesFromCamera() in C:/WindRiver/workspace/WPILib/Vision/AxisCamera.cpp at line 281
[cRIO] Default disabled() method running, consider providing your own
[cRIO] edu.wpi.first.wpilibj.camera.AxisCameraException: No image available
[cRIO] at edu.wpi.first.wpilibj.camera.AxisCamera.getImage(AxisCamera.java:292)
[cRIO] at edu.wpi.first.wpilibj.templates.RobotTemplate.operatorControl(RobotTemplate.java:82)
[cRIO] at edu.wpi.first.wpilibj.SimpleRobot.startCompetition(SimpleRobot.java:118)
[cRIO] at edu.wpi.first.wpilibj.RobotBase.startApp(RobotBase.java:156)
[cRIO] in virtual method #10 of javax.microedition.midlet.MIDlet(bci=17)
[cRIO] at javax.microedition.midlet.MIDletTunnelImpl.callStartApp(64)
[cRIO] at com.sun.squawk.imp.MIDletMainWrapper.main(110)
[cRIO] in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO] at com.sun.squawk.Isolate.run(1506)
[cRIO] at java.lang.Thread.run(231)
[cRIO] in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO] in static method #3 of com.sun.squawk.VM(bci=6)
You get the windriver error because the java files are actually wrapped C-code. Where is your camera plugged in? And did you do the setup utility so it can create the FRC user?
Follow the directions to change the camera configuration to allow anonymous connections.
I plugged the camera into port 2 of the cRIO. I realize that we are supposed to connect it into the router/bridge but I have close to no networking experience. I reset the camera and I manually went into the camera and added a user frc password frc. Would I still need to run the camera setup tool? How would I change the camera config to allow for anonymous connections?
There’s a check box on one of the pages. I don’t have the camera handy, so I can’t confirm where.
