camera
I was wondering if we could use a D-Link camera instead of a axis camera. If yes then do we set it up the same way as the axis?
There are no rules against using a camera other than the Axis camera.
You’ll have to ask a programmer about setup.
This is the first time we are using a camera other than the Axis. No one on our team knows how to set it up.
What do you intend to use the camera for?
The default Dashboard program uses the Axis protocol to get the camera video stream. If you’re using a camera that doesn’t talk that language, you’ll need to do some extra work in order to see Dashboard video.
