Camera
Hello everyone, I’m from a new team in Brazil, and as we are still starting with labview, I would like some help on how to transmit a USB camera connected to the roborio directly to the dashboard. we are having difficulty in this matter
Here’s a snipped of example code (note that the majority of this is already in Periodic Tasks.vi, just make sure the boolean constant at the start is set to ‘True’)
https://www.team358.org/files/programming/ControlSystem2015-2019/labview/index.php#Camera
Here’s the docs on using the default dashboard: FRC LabVIEW Dashboard — FIRST Robotics Competition documentation
(note the comments in Cemera Image and Controls section about using the Mode selector).
Lastly, I will warn you that to use a USB camera with the roboRIO, it is easiest if it is one that will work on the roboRIO with the default USB drivers. (if I recall correctly, the webcam that comes in the KoP does work, but others may not…, may require testing).
