Can a logitec C920 web cam be used for ftc?
I was once told that I could use a normal camera for ftc, and I have a c920 but I don’t know if it really works and I haven’t found how to program it, so could someone please help me, I want to use it for the QR codes of the courts.
So yes, you can use pretty much any camera for ftc. Next thing is what exactly are you programming in, e.g., Java or Blocks? Or if you want, I provided some links that you can read, the titles explain what they are.
ftc docs for april tags
ftc docs for your specific camera
I am programming in android studio and thank you very much for the links.
In Android Studio, there should be some sample code for April tags. When you open your project, you should be able to follow this path to find the sample code: FtcRobotController / src / main / java / org / firstinspires / ftc / robotcontroller / external / samples / ConceptAprilTag.java
Hello, What you will want to do is look at the Vision Portal API that is part of the FTC SDK: VisionPortal Overview — FIRST Tech Challenge Docs 0.3 documentation. In the samples directory you can get started by trying ConceptAprilTag and UtilityCameraFrameCapture. Last season we used a C920 with the VisionPortal extensively. Feel free to ask more questions.
