Can a PCM be used without a pneumatic system
Basically, this is the question: Can a PCM be used without a pneumatic system to control a solenoid?
Basically, yes. There’s no rule saying you can only have a PCM on the robot if you have a pneumatics system.
That being said, what kind of solenoid are you trying to control without a pneumatic system? What are you using it for?
We are using it to release the pressure of a vacuum system. By opening the solenoid, the system will quickly return to atmospheric pressure. It is a regular 12V spring return solenoid that just opens when it’s powered and closes when it’s not. Would you recommend something else?
No, that seems like a good use for a solenoid
Just a warning-standard solenoid valves operate, actually switch, using pilot pressure. Generally, 25-30psi is required on the input line.
So, you’ll need one that isn’t piloted.
How do you know if it is piloted?
Check the documentation for the valve. It will list a range of operating pressures. If you’re within that range you’re good to go.
A vacuum-rated valve callout:
This valve needs a minimum input pressure of 21psi to pilot:
