CAN ANYONE HELP ME PLEASE??
I wrote a this code for our arm release:
if ( (ThirdStick->GetRawButton(6) ) )
   	ArmRelease -> Set(1.0);
   	else
   		ArmRelease->Set(0.0);
   if ( (ThirdStick->GetRawButton(7) ) )
   	ArmRelease ->Set(-1.0);
   else
this means when i press buton 6 on the joystick the motor is supposed to go forward, and when i press button 7 on the joystick the motor is supposed o go backwards. button 6 work, the motor goes forward, but when i press button 7 it doesnt move. i even tried:
                       while (ThirdStick->GetRawButton(7)
                                    ArmRelease->Set(-1.0);
else
but it still dont work! :confused:
Huge flaw in your code. Here’s a hypothetical situation based on the first one shown:
Button is 6 is pressed. The motor is set to 1.0. However, almost immediately after that, button 7 is checked and most likely set to 0.0.
Here’s what I think you want:
if (ThirdStick->GetRawButton(6)) {
    ArmRelease->Set(1.0);
} else if (ThirdStick->GetRawButton(7)) {
} else {
Also, I assume you mean if instead of while in that second code block. That version would only activate button 7 mode if button 6 was pressed
THANKS ALOT MAN!!!, I FORGOT ALL ABOUT ELSE IF STATEMENTS
