CAN error help
ok so weve been dealing with this all day now.
when we turn on our robot we get ERROR<Code> -44087 Occurred at NetComm_Can_Recieve.vi:8
and then when we enable the robot
ERROR<Code> -44087 Occurred at NetComm_Can_send.vi:6
from posts on the fourms we have verified both our terminators work ( am I able to enumerate all the jags with the BDC COMM tool and set their positions and voltages and such)
I places 100ms second waits on both the teleop and dashboard main loops( per http://www.chiefdelphi.com/forums/showthread.php?t=91102)
im still at a loss for these errors
I m running labview 3.1 and the cRio has version 28 on it.
ok so Error send:6 and Receive:8 are from when a CAN ID in your code is unreachable.
so if you see this check the power connections to the jags to make sure every thing is secure.
It sounds like you haven’t installed the BlackJag Plugin.
You can do this from the cRIO reimaging tool.
no that was installed. the problem was one of the Jags came unplugged ( power ) and therefor was unreachable
