Can I use a NavX instead of Pigeon 2 for CTRE Swerve project generator?
I very recently saw that CTRE now has a Swerve Project Generator as a part of their Tuner X software.
Reading the documentation, it seems that it requires a pigeon 2.0 which our team does not have, however we do have NavX’s (as per the title), I am wondering if there is any way possible to use a NavX instead of a pigeon?
No, the built-in latency compensation won’t work unless it is a Pigeon on a CANivore.
Note that our Swerve API does not require the use of a CANivore, you just won’t get the benefits of timesync (requires Pro) and 250 Hz odometry without it. With that said, we do require all devices to be Phoenix 6 devices.
Any advice on the pigeon placement on robot?
I’ve seen most teams put the pigeon (or NavX/other gyro) as close to the center as possible.
It’s best to keep is as close to the center of rotation as possible to avoid sensor saturation. From the user guide:
Due to the fusion between the accelerometer and the gyroscope, excessive and sustained g-force caused by centripetal acceleration can impact the Yaw. This can be resolved by moving the IMU closer to the COR (center of rotation).
