Hello. I have a question about CAN wire colors.
We plan to run two separate CAN networks on our practice chassis and possibly 2025 comp robot if needed. I know the standard CAN wiring is green/yellow. My question is, can we run another color pair for the second CAN network, say, orange/purple or some such, to differentiate between the two?
Or twist in a third color tracer line?
Or even just put some colored electrical tape on the line? I think this would be our least-favorite choice.
I believe the manual just says something like colors are generally green/yellow for CAN lines. I don’t know how strict this is? Would an RI/LRI frown on anything other than standard green/yellow? Thanks.
CAN is a signal-level wire, so doesn’t need to follow the color-coding rules
As mentioned above, CAN wiring color is not restricted by R624 (red & black is not a great choice, though).
Another possible solution is heat-shrink labelling:
I wish my team had color-coded the two buses. I can’t prove that DIN 47100 ever recommended pairings like these but someone on the Internet made this:
I’d definitely recommend color coding the 2 busses. At least at my company, we tend to keep yellow as CAN High, and use green for our primary CAN Low, and purple for our secondary.
As others have said, there is no requirement for CAN bus wires to be yellow & green. However, you do want to make sure that the wires are twisted at around 1 twist per inch. Otherwise (especially with CAN PD) you run the risk of electromagnetic interference or signal reflections messing up communications.
For a CAN FD buss our color choices are Yellow and Blue 22 AWG wire
Legacy CAN remains Yellow and Green
Why not use color coded zipties on critical connections. these can be bought for cheap from amazon…
