CAN on a budget
after my experiences working on getting can to work on my team in the last few months, i decided to make a .pdf on how to make CAN work this year without killing the piggy bank.
I attached it.
comments?
how-to.pdf (65 KB)
how-to.pdf (65 KB)
Thank You for this, I was just researching the best way to go about using the CAN bus. Might I suggest you post this to the whitepapers as well.
i want to do some last proofreading and editing first… once fully polished, it will be headed there.
good luck with you CAN experience!
edit- updated file attached. it will be sent to the whitepapers as well.
how-to.pdf (64.6 KB)
Nice paper.
One point of fact that you may want to look into, there are more than 2 FIRST ‘Legal’ options for CAN. A team could also make their own gateway device using either Ethernet or serial.
Good job.
I was not aware of that. I will research it further.
It has been added as a white paper and i have updated it (attached). It also has a section on how to use a junk serial cable to make the serial adapter (essentially how i made the 2009 KOP cable to work in the first place).
Edit- yes, you can make your own adapter. good call. updated file attached.
CAN.pdf (66.4 KB)
CAN.pdf (66.4 KB)
lots more original pictures have been added
the new version is at http://www.chiefdelphi.com/media/papers/2433
enjoy!
