We are experiencing issues with labview program and getting our arm to move to a position on button command. Nearly nothing happens once enabled and button is clicked. The motors stutter slighty if touched, but after there is no response. yes we did update firmware, set up individual id’s and searched the software reference manual
Here are the begin, teleop, and PID values.
Any help appreciated
What PID values are you using?
The links were active just long enough for me to glance at them and not see anything immediately relevant to the problem.
I did notice that you’re doing some very weird things when reading the joystick buttons. You get two copies of the Device Reference, passing each to a separate Joystick Get, and you use two completely different methods of getting the desired button value out of the Buttons array. That won’t cause the symptoms you describe, but it is definitely not a clean way to do it. You should just get the Buttons array once, and pull all of the values out of it that you need (using either the array-to-cluster or the Index Array method, but not both).
I didn’t have a chance to see whether the PID values looked reasonable, or whether the limit switch settings made sense, or whether the control mode was set appropriately.
