Can we use Palettes???
Hi Eveybody, this is our second year in FRC and we are still rokies :slight_smile: I just wanted to ask that if we can use palettes or not because they will be beneficial if use them to avoid the bumps.
Not sure what you are asking here…
If what you suggest is using something that extends outside the robot to assist you in climbing the bump then the answer is no. The robot can only grow beyond the FRAME PERIMETER in order to right itself or in the FINALE. Sorry.
Yeah, try re-wording your question so we can better understand what it is you’re asking. Generally materials are unrestricted (apart from the material use rules in the Robot section of the 2010 FRC manual.), however, the WAY in which they’re used must abide by all game and robot rules.
