We are having issues with screws gradually getting unscrewed while our motor is spinning, and we were wondering if it is safe to put loctite inside the output shaft.
Loctite every screw that goes into a Falcon or it will wiggle it’s way loose.
Loctite in the shaft will not hurt anything therefore yes, I’d recommend applying it to shaft retention screws as well.
I recommend 243.
I believe he is reffering to the screw on the main shaft. The one preventing the pinnion and spacers from coming loose…
I’d recommend loctite on all 6 screws including the retention screw in the end.
We are using the standard falcon output shaft
