Is it ok to wire the CTRE CANCoder to the VRM 12v500mA or does it have to be wired to the PDP? As far as I can tell it would have the same volts and more than enough amps from both.
The CanCoder is good to 6V so you could probably do either and not have a problem. The VRM will give you a little better margin of safety.
Ok thanks
