When using the characteristics of the robot, I encountered the following problem:
I don’t understand why this happens, since the status of the network tables is “NT connect” in the logger, but if you run one of the tests and activate the offline mode, then nothing happens, I specified all the engine connections, and yes, when this error occurs, I I can connect to the controller at the same addresses via SSH
