Cannot find libCTRE_PhoenixCCI.so on roborio, even though it exists
Interesting issue I am having here, never seen this before. Every single time I try to deploy code to the roborio, it does successfully and then returns this:
java.lang.UnsatisfiedLinkError: /usr/local/frc/third-party/lib/libCTRE_PhoenixCCI.so: libFRC_NetworkCommunication.so.22: cannot open shared object file: No such file or directory
Now I used FTP to look at the robotio, to see if I could copy one I found on my pc, but the file does exist on the robotio. Im confused
It’s not saying libCTRE_PhoenixCCI.so couldn’t be found. It’s saying libFRC_NetworkCommunication.so.22, a library libCTRE_PhoenixCCI.so links to, couldn’t be found. Did you use a 2022 version of CTRE’s vendordep in a 2023 robot project by mistake?
potentially, how can I fix this, I think ive reinstalled the right json
Once you’ve put the proper json in the vendordeps folder, just run a build/deploy.
No, ive looked at the vendordeps and it says that I have the 2023 version. frcYear is set to 2023
If that’s the case, it makes no sense that it would be linked to the 2022 version of netcomm.
Have you run a build when connected to the internet?
What is the exact version in the file, not just the frcYear?
Yeah I have run the build when connected to both WiFi and ethernet.
Currently on version: 5.31.0+23.2.2
JSON URL: https://maven.ctr-electronics.com/release/com/ctre/phoenix/Phoenix5-frc2023-latest.json
Is there another phoenix vendordep json in the vendordeps directory?
Sorry, went to sleep and didn’t see this.
Not, I only have Phoenix is there
