Hello,
This issue may be similar to others I have had, but I feel it is different enough to warrant a new post. I apologize if I am wrong with that.
I am trying to use the Photon simulator object described here.
However, I cannot get the vendor libraries to work. Here is the error I see.
Could not resolve all files for configuration ':runtimeClasspath'.
> Could not find org.photonvision:PhotonTargeting-java:v2021.1.5-4-g00b8e7d1.
Searched in the following locations:
- file:/C:/.../wpilib/2021/maven/org/photonvision/PhotonTargeting-java/v2021.1.5-4-g00b8e7d1/PhotonTargeting-java-v2021.1.5-4-g00b8e7d1.pom
- https://frcmaven.wpi.edu/artifactory/release/org/photonvision/PhotonTargeting-java/v2021.1.5-4-g00b8e7d1/PhotonTargeting-java-v2021.1.5-4-g00b8e7d1.pom
- https://maven.photonvision.org/repository/internal/org/photonvision/PhotonTargeting-java/v2021.1.5-4-g00b8e7d1/PhotonTargeting-java-v2021.1.5-4-g00b8e7d1.pom
- https://maven.photonvision.org/repository/snapshots/org/photonvision/PhotonTargeting-java/v2021.1.5-4-g00b8e7d1/PhotonTargeting-java-v2021.1.5-4-g00b8e7d1.pom
- https://repo.maven.apache.org/maven2/org/photonvision/PhotonTargeting-java/v2021.1.5-4-g00b8e7d1/PhotonTargeting-java-v2021.1.5-4-g00b8e7d1.pom
Required by:
project :
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output. Run with --scan to get full insights.
* Get more help at https://help.gradle.org
I also tried running the code from the example libraries, but I cannot figure out how to make them work (which folder should be top-level for the build.gradle to function correctly).
Thank you for the reply. I tried the last url, and it did not load correctly. However, I remembered (from one of my other issues), that the beta is not building on Windows.
So, I tried this Vendor dep file and built it while connected to the Internet, and it seems to work (it builds and runs the simulator perfectly).
I just had a few more moments to poke around, and it totally works. I am currently using the sample code from Photon’s repo. It is working perfectly out of the box. We drive a bit, press the button, and the robot moves to the desired range while lining up. This really is a helpful tool.
