Can't change the neutral mode of several talonSRX controllers
We are currently having issues with changing our talons’ neutral mode.
It seems that other settings still do work and we can change anything else just fine but when it comes to changing the neutral mode it seems to not respond.
We are using the phoenix tuner to test our changes and we know we can change it straight from there but it seems that when we try to change it from the code is when it doesn’t work.
Below is the minimal code we used to test it after it wasn’t working on the actual code we were working on.
/* Copyright (c) 2017-2018 FIRST. All Rights Reserved.                        */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package robot;
import com.ctre.phoenix.motorcontrol.NeutralMode;
import com.ctre.phoenix.motorcontrol.can.TalonSRX;
import edu.wpi.first.wpilibj.command.Command;
import edu.wpi.first.wpilibj.command.Scheduler;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the TimedRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the build.gradle file in the
 * project.
    public TalonSRX testMotor = new TalonSRX(16);
    Command m_autonomousCommand;
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
    @Override
    public void robotInit() {
     * This function is called every robot packet, no matter the mode. Use
     * this for items like diagnostics that you want ran during disabled,
     * autonomous, teleoperated and test.
     * <p>This runs after the mode specific periodic functions, but before
     * LiveWindow and SmartDashboard integrated updating.
    @Override
    public void robotPeriodic() {
     * This function is called once each time the robot enters Disabled mode.
     * You can use it to reset any subsystem information you want to clear when
     * the robot is disabled.
    @Override
    public void disabledInit() {
    @Override
    public void disabledPeriodic() {
     * This autonomous (along with the chooser code above) shows how to select
     * between different autonomous modes using the dashboard. The sendable
     * chooser code works with the Java SmartDashboard. If you prefer the
     * LabVIEW Dashboard, remove all of the chooser code and uncomment the
     * getString code to get the auto name from the text box below the Gyro
     * <p>You can add additional auto modes by adding additional commands to the
     * chooser code above (like the commented example) or additional comparisons
     * to the switch structure below with additional strings & commands.
    @Override
     * This function is called periodically during autonomous.
    @Override
        Scheduler.getInstance().run();
    @Override
    public void teleopInit() {
        testMotor.setNeutralMode(NeutralMode.Coast);
     * This function is called periodically during operator control.
    @Override
     * This function is called periodically during test mode.
    @Override
    public void testPeriodic() {
Thank you!
I don’t know much about programming, but are the controllers running the latest firmware?
