Can't deploy paths to robot: deploy frcStaticFile Deployroborio failed
Hi everyone,
I’m encountering an issue deploying my paths to my robot.
Whenever I attempt to deploy my robot, it errors.
I’ve isolated it to this to be the problem because when I took the paths folder out of the deploy directory, it worked fine.
The file structure is below.
We cannot get our robot to deploy, but we need these paths.
Any help would be appreciated, thanks!
That’s certainly weird. Do you have this code (with paths) committed to github or anything that we can look at?
You can view the code Here as its laid out in the file system on the development computer.
I don’t think it has anything to do with the code itself as I can’t even get the code to deploy onto the robot lol
Everything else goes fine except that one step.
I can’t see anything wrong in the code. Sometimes the deployer just gets confused. You might want to try re-imaging your RoboRIO.
For whatever reason, deploying it over USB got it working. Thank you both for the help!
