Code ran fine for 2021. Updated PC to 2022 LabView. Updated roboRio to 2022
Now any code won’t download to roboRio. It gets so far and then says it can’t connect to target.
This happens 19 times out of 20.
Wireless off
Tried 3 USB cables.
Updated roboRio firmware from version 6 to 8
Tried a second roboRio.
Made sure all anti-malware was turned off on the PC.
Before 2022 the same PC with the same roboRio loaded just fine…
Thanks for your reply. We did the firmware first. Then the 2022 stuff. That is when the problems started. Then we fell back to the previous firmware then loaded the 2022 stuff.
All was well before the upgrades. Not sure how to procede
I might be giving you a bit of a red herring but have you tried using SSH to access the RoboRio to find the problem. I have ran into a few errors where it decided to change its IP address to something random.
I know my suggestion only helps for wireless issues but if you are totally lost I guess it’s worth a shot.
Sorry to be so late replying.
Right click on Target. Choose Properties.
Leave the name as Target but change the address to 172.22.11.2 instead of
the DNS name. That fixed it for us.
