We added the code for event logging based on this documentation. When reviewing the log file using the Driver Station Log File Viewer, we don’t see the commands logged. We did change the filter to show all events and still didn’t see any commands logged.
I expect we are missing something simple. Is there another configuration step that is required? Thanks for any tips!
Can you show your code? Ideally as a link to github. I suspect it’s just a misunderstanding about what this docs page is saying vs what you’re trying to do.
That provides some help as I’m no longer confused why we don’t see anything in the Driver Station Log File Viewer. How do we view these event markers? Are they only visible when viewing a recording? I’m not sure where to look or what widgets to add to Shuffleboard to see them…
Did you ever find an answer to this question. I also have the exact same query from the exact same source code and was about to post the question CD when I came across your post.
I ran the Scheduler Event Logging example in simulation, started shuffleboard, started recording, pressed some buttons, stopped recording, and exported the recording to CSV and got the following. It doesn’t appear to have logged the instant commands, though.
