this is my second post today already
here is my error now
Executing task: gradlew deploy -PteamNumber=5429 --offline -Dorg.gradle.java.home=“C:\Users\Public\frc2019\jdk” <
Task :discoverRoborio
Discovering Target roborio
admin @ roborio-5429-FRC: Connected.
Reason: InvalidImageException
RoboRIO Image invalid! RoboRIO: 2020_v10, allowed: [2019_v12, 2019_v13]
3 other action(s) resolved but not connected.
2 other action(s) failed resolution.
1 other action(s) not started.
Run with --info for more details
Task :discoverRoborio FAILED
FAILURE: Build failed with an exception.
- What went wrong:
Execution failed for task ‘:discoverRoborio’.
A failure occurred while executing jaci.gradle.deploy.target.discovery.TargetDiscoveryWorker
Target roborio could not be found at any location! See above for more details.
Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output. Run with --scan to get full insights. -
Get more help at https://help.gradle.org
BUILD FAILED in 4s
6 actionable tasks: 2 executed, 4 up-to-date
Missing Target!
Are you connected to the robot, and is it on?
GradleRIO detected this build failed due to not being able to find “roborio”!
Scroll up in this error log for more information.
The terminal process terminated with exit code: 1
