I tried running some code on our bot and kept getting this in the RioLog:
➔ Launching «'/usr/local/frc/JRE/bin/java' '-Djava.library.path=/usr/local/frc/lib/' '-jar' '/home/lvuser/FRCUserProgram.jar'»
********** Robot program starting **********
Error at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:249): ERROR Unhandled exception: java.lang.RuntimeException: Code: -1029. HAL: Resource already allocated at [edu.wpi.first.wpilibj.hal.PWMJNI.initializePWMPort(Native Method), edu.wpi.first.wpilibj.PWM.<init>(PWM.java:61), edu.wpi.first.wpilibj.SafePWM.<init>(SafePWM.java:24), edu.wpi.first.wpilibj.PWMSpeedController.<init>(PWMSpeedController.java:23), edu.wpi.first.wpilibj.Talon.<init>(Talon.java:36), edu.wpi.first.wpilibj.RobotDrive.<init>(RobotDrive.java:94), org.usfirst.frc.team6620.robot.Robot.robotInit(Robot.java:35), edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:64), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:247)]
WARNING: Robots don't quit!
---> The startCompetition() method (or methods called by it) should have handled the exception above.
I looked over the code several times and couldn’t figure out what the problem was. The last time I was having problems it was a common sense fix but I was being rushed and missed it but this time I have no clue what’s going wrong with the code:
package org.usfirst.frc.team6620.robot;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.RobotDrive.MotorType;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the IterativeRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
RobotDrive myDrive;
Joystick left, right;
Jaguar climber = new Jaguar(4);
final String defaultAuto = "Default";
final String customAuto = "My Auto";
String autoSelected;
SendableChooser<String> chooser = new SendableChooser<>();
* This function is run when the robot is first started up and should be
* used for any initialization code.
@Override
public void robotInit() {
myDrive = new RobotDrive(1,2,3,4);
left = new Joystick(0);
right = new Joystick(1);
chooser.addDefault("Default Auto", defaultAuto);
chooser.addObject("My Auto", customAuto);
SmartDashboard.putData("Auto choices", chooser);
myDrive.setInvertedMotor(MotorType.kFrontLeft, true);
myDrive.setInvertedMotor(MotorType.kRearLeft, true);
myDrive.setInvertedMotor(MotorType.kFrontRight, true);
myDrive.setInvertedMotor(MotorType.kRearRight, true);
* This autonomous (along with the chooser code above) shows how to select
* between different autonomous modes using the dashboard. The sendable
* chooser code works with the Java SmartDashboard. If you prefer the
* LabVIEW Dashboard, remove all of the chooser code and uncomment the
* getString line to get the auto name from the text box below the Gyro
* You can add additional auto modes by adding additional comparisons to the
* switch structure below with additional strings. If using the
* SendableChooser make sure to add them to the chooser code above as well.
@Override
autoSelected = chooser.getSelected();
// autoSelected = SmartDashboard.getString("Auto Selector",
// defaultAuto);
System.out.println("Auto selected: " + autoSelected);
* This function is called periodically during autonomous
boolean hasRun = false;
@Override
if (!hasRun) {
switch (autoSelected) {
case customAuto:
myDrive.drive(1.0, 0);
Timer.delay(3); //TODO: Set appropriate forward movement duration
myDrive.stopMotor();
break;
case defaultAuto:
myDrive.drive(.5, 0);
Timer.delay(2); //TODO: Set appropriate forward movement duration
break;
default:
break;
public void disabledInit() {
hasRun = false;
* This function is called periodically during operator control
@Override
int controlScheme = 1;
while (isOperatorControl() && isEnabled()) {
//Check for control scheme switch...
if (right.getRawButton(7)){
if (right.getRawButton(9) && !right.getRawButton(11)) {
controlScheme = 1;
} else if (right.getRawButton(11) && !right.getRawButton(9)) {
controlScheme = 2;
//Run selected control scheme...
switch (controlScheme) {
case 1:
while (!right.getRawButton(7)) {
myDrive.tankDrive(left, right);
Timer.delay(0.01);
if (left.getRawButton(4)) {
climber.set(-1.0);
} else if (left.getRawButton(3)) {
climber.set(-0.35);
} else {
climber.set(0.0);
break;
case 2:
myDrive.arcadeDrive(right, true);
Timer.delay(0.01);
climber.set(-1.0);
climber.set(-0.35);
} else {
climber.set(0.0);
break;
default:
Timer.delay(0.01);
climber.set(-1.0);
climber.set(-0.35);
} else {
climber.set(0.0);
break;
* This function is called periodically during test mode
@Override
public void testPeriodic() {
