Help! Our team can’t upload code to our robot. When I try, I get this error message:
Buildfile: C:\Users\James Larson\eclipse-workspace\TestBoi2018 (Working Backup)\build.xml
Trying to override old definition of task classloader
clean:
[delete] Deleting directory C:\Users\James Larson\eclipse-workspace\TestBoi2018 (Working Backup)\build
[delete] Deleting directory C:\Users\James Larson\eclipse-workspace\TestBoi2018 (Working Backup)\dist
compile:
[mkdir] Created dir: C:\Users\James Larson\eclipse-workspace\TestBoi2018 (Working Backup)\build
[echo] [athena-compile] Compiling src with classpath=C:\Users\James Larson\wpilib\user\java\lib\CTRE_Phoenix.jar;C:\Users\James Larson\wpilib\java\current\lib\WPILib.jar;C:\Users\James Larson\wpilib\java\current\lib
tcore.jar;C:\Users\James Larson\wpilib\java\current\lib\opencv.jar;C:\Users\James Larson\wpilib\java\current\lib\cscore.jar;C:\Users\James Larson\wpilib\java\current\lib\wpiutil.jar to build
[javac] Compiling 1 source file to C:\Users\James Larson\eclipse-workspace\TestBoi2018 (Working Backup)\build
jar:
[echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
[mkdir] Created dir: C:\Users\James Larson\eclipse-workspace\TestBoi2018 (Working Backup)\dist
[mkdir] Created dir: C:\Users\James Larson\eclipse-workspace\TestBoi2018 (Working Backup)\build\jars
[echo] [athena-jar] Copying jars to build/jars.
[copy] Copying 6 files to C:\Users\James Larson\eclipse-workspace\TestBoi2018 (Working Backup)\build\jars
[jar] Building jar: C:\Users\James Larson\eclipse-workspace\TestBoi2018 (Working Backup)\dist\FRCUserProgram.jar
get-target-ip:
[echo] Finding roboRIO…
[find-roborio] trying 172.22.11.2
[find-roborio] trying 10.59.14.2
[find-roborio] could not resolve roboRIO-5914-FRC.frc-field.local
[find-roborio] could not resolve roboRIO-5914-FRC.lan
[find-roborio] could not get IP from DS
[find-roborio] Could not connect to 10.59.14.2
[find-roborio] Could not connect to 172.22.11.2
[find-roborio] could not resolve roboRIO-5914-FRC.local
BUILD FAILED
C:\Users\James Larson\wpilib\java\current\ant\build.xml:63: Assertion failed: Property ‘roboRIOFound’ doesn’t exist in this project.
roboRIO not found, please check that the roboRIO is connected, imaged and that the team number is set properly in Eclipse
Total time: 6 seconds
Help is greatly appreciated!
