This is the console-out from NetBeans containing our entire boot-up process with our CANTimeoutException. We were able to flash our Jaguars with the latest firmware using the 2CAN web interface, which makes us think that the CAN network is correctly set up. After the code deployment is complete, the 2CAN is flashing green fast, which indicates that the cRIO is communicating with the 2CAN. You can see from the console-out, the 2CAN plugin is loading properly. If we remove the 2CAN from the Ethernet network, we get an UncleanStatusException.
Our question is: what else can we do to troubleshoot the CANTimeoutException?
Thanks in advance for the advice.
