Carpet
where are the specs for the carpet? please and thank you
3.2.1 Boundaries and Markings
The carpeted Playing Field is 48 feet by 24 feet, bounded by two Walls and a Guardrail System. The Guardrail System is a 20-inch high horizontal pipe with vertical supports mounted on a 3” aluminum angle. A 3/16” stranded steel cable runs through the vertical supports mid way between the angle aluminum and the top pipe.
http://www2.usfirst.org/2004comp/3-TheArena-RevC-markup.pdf
Please Take Note:
This (of course) refers to the 2004 carpet.
We STILL don’t know 2005’s rules/regs/specs.
(Sorry Katie, couldn’t help it!)
From the 2003 Supplier List:
S. S. Mills
Dalton, GA
800-241-4013
From 2002 Game rules, same supplier: Brassfield 20, color-Black Coal
From 2004 Supplier list, same supplier: Sequoia 20,#30550 ground pepper
