https://sphotos-a.xx.fbcdn.net/hphotos-prn1/535550_10152570391430517_1246750305_n.jpg
Must go into competition with all possible catalyst records. Cannon record achieved.
Cannon no climber-
117 points, including 48 point auto.
I think I’ve hit 120 a few times with Cannon No Climber after the update, but I know Gregor has hit a higher score than that.
I think my max is like 59 or something with Ri3D.
I cant get even 3 pts with Ri3D…
You kinda have to jam it into the center of the pyramid, but not too hard, to get 3 point shots working right. Takes a few minutes to figure out.
This was a 48 point auto, all white disks off the floor, 2 trips to the feeder station, 1 red disk, 5 blue disks, and 1 blue disk in the pyramid goal. The score should have been 135, the HP got me 2 points.
Can you post a Faps of your gameplay, because I don’t understand this 42 pt auto…I can only get 36.
Start in blue 1. Turn a little bit, score your 2 preloads. Grab the 2 middle disks and shoot under the shadow. Grab the 2 front disks, shoot 1 under the shadow and one at the blue line without stopping, then go straight back to the centre, grab the 2 disks, and shoot them from the blue line. With this method I can score 8 disks and grab 2 more disks in auto.
I’ll try and record a video later, but I’m running it on a Macbook and don’t have the software installed. Anyone have some decent screen recording programs they can reccomend?
*It is important in this step to not stop, shoot as you move back.
QuickTime can do screen capture too now. Not the best frame rate every time but it will work.
You can also do an 8 disc auto from Blue 2 and going backwards, but it’s a bit slower. I find it easier with an Xbox controller for some reason.
You can get the disks below the pyramid in autonomous.
Cannon no climber. 138
I’ve not been able to score reliably in the 3 pt. goal with walking tail post update. The disks sometimes just barely fall in, but most of the tome they wont reach the goal.
You have to hit the wall, and then barely move back. That should help.
I believe my highest score was around 138. I played it way too much for about 3 days.
Exactly. If you look at the time on my photo, it says that I played past midnight. I was really irritable at our event that day. I just posted it because I never got around to it.
Pardon the thread bump, but some of us just finished finals and now are back to their Catalyst habit.
I have no idea how you can score more than 129 points. That’s every disc on the floor, with a seven disc auto, and all six colored discs in the tower. Even one cycle from the human player would raise that total to 141.
