Catalyst 2013 High Scores
Mine with Walking Tall :slight_smile:
You guys are amateurs.
https://sphotos-a.xx.fbcdn.net/hphotos-frc1/737240_4031649481674_794440837_o.jpg
HACKS!!! But, Seriously good job! How many times did you have to restart it?
How do you lower the shooter on Walking Tall after you raise it? Both are supposedly bound to Left Ctrl but pressing it again does nothing.
This had to be my 30th or 40th attempt. I average just over 100.
As for Walk Tall’s keyboard controls, I don’t know them. I still use the same wired Xbox controller I used to play 5th Gear 2010 when it first came out, lol.
Strategy is pretty simple: 4 discs in auto, usually one run of discs in teleop before going for the colored discs. If you do it efficiently enough that you’re out of discs just before the 30 second mark (if you’re going for high score, you should), then you go get the last two red disks. The last 30 seconds is really where high speed scoring is at.
:slight_smile: try to beat this 6 discs in auto., 4 discs in 5pts, and the rest just white in 3pts.
(if you run to feeder station for 2 red, you get more pts. by getting 4 white.)
…and do the bonus still count in the real game if the HP knock your red/blue frisbees out?
played again today, and got even higher :slight_smile:
(only 4 bonus disks, I found out 4 bonus disks and 4 regular disks > 6 bonus discs)
99 using Cannon, no hanging, no pyramid goal bonus discs.
-Nick
wow! nice, can you share how you did that? where you lined up to shoot, etc
Started in Blue 2, shot 4 in auto. Then ran shooting cycles from the discs in the center of the field. Shot from inside the pyramid lined up with the blue line at the back of the structure. As for end game, you should be running your last shooting cycle by about 40-35 seconds to go, but shoot them with the back of the robot halfway through the shadow of the pyramid, then just keep grabbing two from the human player thrown discs and shooting them from there. All discs go into the high goal.
-Nick
So is it just me, or is that walking tall bot totally illegal? They should also put the perspective at eye level with the driver stations rather than well above the driver’s station.
More videos please!
Very insightful.
Walking Tall is completely illegal. DBS said they would fix the height so that it was legal in an update coming this Sunday.
Highest Score with the update :slight_smile: Still waiting for chris.is.me to beat me…
(To attach a photo just use /""] Tags)
I haven’t been able to get Walking Tall to consistently go in after the update. Any tips?
Instead I’ve been trying to use the upgraded Cannon hanger design to get up there, and I’m at like the 105 level with that. I bet with enough skill I could do it, the problem is once you run out of field discs there are massive diminishing returns on going to the human player for points and you just can’t get above that threshold 2 discs at a time. Walk Tall has the red discs as an option and holds 4 so that’s why it can get better scores… Now I just gotta make the new design go in the goal every time.
I’ll have time to attack your high score this weekend, robotics is eating all of my time that school didn’t already consume.
start at red 2, get the one frisbee from under the tower so you have 4, score turn around get the 2 (6 in auto.) then clear the middle, 4 red, 1 run of 4 white frisbees, and quick score in the last 20 seconds.
(you have to line up perfectly, take your time)
That’s the general strategy I’m using, the problem is for some reason when I’m up against the wall about half of my frisbees don’t make it into the goal. I can’t tell what I’m doing wrong. I’ll take video next time I do it.
I usually hold the joystick so I don’t move back at all.
I found out the problem. I play with an Xbox controller, and for Walk Tall, the spit speed seems to be determined by how hard you hit the A button.
Since I didn’t like smacking my thumb every time i wanted to score, I switched to the cannon. My high score with that is 120, which is within 8 points of the mighty Original Walk Tall.
…and 5 points away from the updated walking tall! Great job, I cant get the shooting spot down for cannon :confused:
If you run into the tower (the side closest to “you” and so it is pointing straight at where you are trying to score), you will score 3 pointers. With this, I am able to clear out the entire middle field frisbees, get 24 pts in auton, and climb for a 30, getting on average 114 pts total. Not as good as the walking tall but thats all I can get with the cannon…
