Catalyst controls help
I am using an xbox 360 wired controller that I can assign with a program I got but when I use it with Catalyst the control scheme does not work and it uses the preset for Catalyst. Does anybody know how to fix this or has run into this problem before? :slight_smile:
We figured it out. You sign into Catalyst as a keyboard then when you are playing you plug-in your controller and your assigned keys should work.
