Thanks, Yes it is a very simple mechanism, and it is easy to get on.
Your ring grabber must be feeling pretty lonely with no one paying any attention to it, but I think it’s pretty interesting. Is it automated, or does the driver have to run all the actuators separately?
The driver does do all the driving. There are limit switches that help the driver out a little bit and there is a pot that we can view the value on the OI.
What motion/axis is the pot feedback for? I think using OI feedback is a good idea for troubleshooting, but do your drivers find it useful in competition, too?
The pot feedback is for the position on the arm. It allows the programmers to put in dead zones, which are very helpful, and it allows us to know when we are in position to grab a tube. Plus we have what is called “Gas Mode” which is for the case that the programming goes bad or something for some reason, which allows the drivers have complete control and have no stops or any limits on any of the motions, so yes reading the pot is very useful to the drivers.
Hi Pete,
The ring grabber that you inquired about is pretty much automated, but the arm operator needs to coordinate opening the device with lowering the trolley.
The trolley is what allows the arm to move up and down a mast, as the motor walks up and down a chain. The bucket is hinged and opens and closes using a mechanism attached to a rack, which is driven by the window lift motor. At a specific point in the rack travel, the bucket is articulated open.
So, the arm operator simply locates overs the tube, and while lowering the trolley they push a button to drive the rack motor. While the tube pusher moves away from the tube, the bucket opens to clamp against the inside part of the tube. There is a switch to shut off the motor at the end of both the open and close travel positions.
The bucket also acts as a guide when aligning with the rack spider leg.
It didn’t take the arm operator long to attain the skill to get really good at grabbing the tubes.
Mike
