Change loop time in C++
Anyone have sample code on how to change the default loop time in C++?
I’m a newer programming mentor and I am not strong on C++ syntax. I found the following on the FIRST resources site, but I’m not sure if this goes in the Robot.h header file under public: or elsewhere.
Robot(): frc::TimedRobot(30_ms){};
I get build errors when I try to do
class Robot : public frc::TimedRobot(30_ms) {
For more info, our code can be found under https://github.com/feds201/2020_Robot_Code
That snippet is the constructor.
class Robot : public frc::TimedRobot {
 public:
  Robot() : frc::TimedRobot(30_ms) {}
Thank you! I didn’t get a build error. I’ll try this on the robot tomorrow.
