TL;DR: How can I constrain max acceleration/velocity during a WPI Lib trajectory based on progress instead of position?
Hi! I’m the lead programmer for team 3018 and I’m working on implementing a easy-to-use path system based on the WPI Lib trajectory system. I’m using Java.
I have a question/feature request about the trajectory constraints available. I want to have the ability to change max speeds/acceleration in the middle of a trajectory. So at the start it might have max acceleration of 3 m/s, set in the TrajectoryConfig
. Then I set it to go to waypoints A, then B, then C. Then, I would want to set to change the max acceleration value to 2 m/s, then go to waypoints D and E.
I would think that using a TrajectoryConstraint
would be good here, except that it does not accept anything related to progress, only the current position.
The interface for TrajectoryConstraint looks like
public MinMax getMinMaxAccelerationMetersPerSecondSq(Pose2d poseMeters,
double curvatureRadPerMeter,
double velocityMetersPerSecond) {
which is good, but what would be great was if there was an additional parameter double time
. Then it could switch based on how far through the trajectory it is. The RectangularRegionConstraint
doesn’t work because it applies to that area throughout the whole trajectory, not just after some time.
For example, a path might include driving straight forward, dropping off a heavy load, then driving back all in the same trajectory. A rectangular region would affect speed the whole time, when I just want it on the way back.
My current solution is basically to generate another trajectory while the robot is moving as soon as it hits the end of a certain acceleration area. So the robot begins following a new trajectory that starts right at its current position. I think this has problems however. One is the time taken to generate the new trajectory, but it’s probably OK since the doc says it will only take 25ms. A bigger issue is that it might magnify any current position errors.
So: Is hot-swapping Trajectories the best way, or is there some way to use constraints?
Sorry for the long post, I wanted to make sure to get out all the information that might be useful.
