Hello All,
I am writing this as a follow-up question to Mike Betts post on this thread:
https://www.chiefdelphi.com/forums/showthread.php?t=38539
Which Was:
(1) Make both the motor and generator the same type of motor.
(2) Wire a power resistor across the generator’s electrical “outputs”. Be careful to size the resistor properly.
(3) Measure the voltage and current at the “input” and “output”. Also measure the speed at the spindle/coupler.
(4) Adjust the input voltage to a known value (in our case it’s almost always 12.0V). Note that you do not need a precision high current power supply… Just use an Exide SLA and let it slowly discharge as you run the MG and take your readings at 12V.
Note also that you can ignore (4) depending on exactly the type of data you are going for…
For a given load resistance, you will take your readings:
Input Power (W) = Input Voltage (V) * Input Current (A)
Output Power (W) = Output Voltage (V) * Output Current (A)
Mechanical Power at coupler (W) = [Input Power (W) + Output Power (W)] / 2
Torque at coupler (N*m) = Mechanical Power (W) / Spindle Speed (radians/sec)
Power Lost in Motor (W) = Input Power (W) - Mechanical Power at Coupler (W)
This sounded like a great way to DIY at home so I mimicked this type of setup with a adjustable DC Load as my power resistor and I collected a bunch of data. Now I am going over the data I collected and I wanted to check back about the testing methodology I used as far as how well it should work out. That said I am not looking for something super accurate, but I was hoping to get reasonable numbers using this method.
In my tests I used 2 sets of different 550 series DC motors rated for 18v. Set 1 was identical and set 2 were identical to each other. These were motors approximately the type you may find in a 18v drill.
From my research to similar motors I expected these motors were rated for approximately 200-250w maximum with maximum efficiency to be at 6-10amps.
Below is some of the data I collected on the two motors. Does it look like I did this right? Knowing that the stall torque should be just under 500(mN-m) does the operating torque I measured seem right?
Any help, suggestions, and feedback would be truly appreciated!
Thank you!
Motor 1
Input Output Coupler
In V In A In W Out V Out A Out W M Power RPMs Rads Torq P Lost
17.2 13.0 222 6.8 11.0 74 148 13100 1370 0.110 74
17.2 14.0 239 5.0 12.0 61 150 14200 1490 0.100 89
17.4 12.0 209 7.0 10.0 71 140 13300 1390 0.100 69
14.4 12.4 176 4.4 10.0 43 109 10600 1115 0.100 67
14.0 12.4 172 4.4 10.0 44 108 10400 1090 0.100 64
11.0 12.0 134 2.2 9.8 21 78 7400 775 0.100 57
10.0 11.6 118 1.4 10.0 13 66 6800 710 0.095 52
12.0 11.8 142 3.0 9.6 28 85 8500 885 0.095 57
17.4 11.2 195 7.2 9.0 65 130 13900 1455 0.090 65
Motor 2
15.0 16.2 242 7.6 10.0 77 159 13800 1440 0.110 82
15.0 15.4 228 8.0 10.0 80 154 13900 1455 0.105 74
13.2 14.4 189 6.2 10.0 61 125 11800 1240 0.100 64
12.6 14.2 176 6.2 10.0 63 119 11500 1205 0.100 57
9.0 13.0 116 3.8 9.8 37 76 7500 785 0.100 40
12.0 13.6 164 6.2 9.8 60 112 11300 1180 0.095 52
11.0 13.6 149 4.8 9.8 48 98 9600 1010 0.095 50
10.0 13.4 133 3.8 9.8 38 86 8700 910 0.095 47
8.2 12.2 99 3.4 9.6 32 66 6600 690 0.095 33
