Hi,
Any time I attempt to open the .chm files provided by WPI -
CPPReference.chm
and
NIVisionCVI.chm
I get the following error:
Action canceled
Internet Explorer was unable to link to the Web page you requested. The page might be temporarily unavailable.
Please try the following:
Click the Refresh button, or try again later.
If you have visited this page previously and you want to view what has been stored on your computer, click File, and then click Work Offline.
For information about offline browsing with Internet Explorer, click the Help menu, and then click Contents and Index.
Internet Explorer
then, on attempting to browse to any pages, I get
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
See if your Internet connection settings are being detected. You can set Microsoft Windows to examine your network and automatically discover network connection settings (if your network administrator has enabled this setting).
Click the Tools menu, and then click Internet Options.
On the Connections tab, click LAN Settings.
Select Automatically detect settings, and then click OK.
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Cannot find server or DNS Error
Internet Explorer
So I am unable to use the WPI help files. Has anyone else had this problem? Have you figured out a solution?
