Thank you to everyone who responded to this. Ok, first and foremost, I understand the relay-based posts, and seems like something I can do, but just in case my description wasn’t clear enough, allow me to rephrase.
This is a video of the car which won the Northeast Hydrogen Fuel Cell Car Regional Competition.
You’ll notice in the video I was charging right to the last few seconds until the start of the race.
When the car crossed the finish line, the guy who I asked to stop the car crushed the chassis and bent the front axle–not exactly something I want to happen.
I want to improve the design so that all I have to do is plug the car into the charging station, go to the finish line with the push button in hand, push the button to start the car, and catch the car myself when it crosses the finish line.
The car is charging throughout the entire before-the-race period. When I press the button, the car’s circuit changes in such a way that the onboard fuel cell is not being charged anymore, but is instead discharging itself into the motor, thus making the car move.
As the car moves away from the charging station, the plug(s) disconnect and the car is now accelerating untethered toward me at however fast it will go.
I could develop some sort of automated stopping system (I’m thinking reed switches) but I’ll save that for later.
There are two main components to this whole system:
- The fuel-cell powered car itself
- The charging station
The fuel cell car obviously has a fuel cell which electrolyzes the water separating it into hydrogen and oxygen. It takes 4 volts max (as per the manufacturer’s specs) any more may destroy it. So, I either have a DC-DC converter on the car, or in the charging station. The car also will have some sort of plug (similar to the speaker plugs found between headphones and iPods, but easier to separate). That way, as it’s starting, the plug connecting the car and charging station separate, and the car races down the track untethered.
The charging station needs the plug, or similar energy-transfer device, and the power source, in my case, probably a battery. The push button is also connected to the charging station. Using either remote control or a really long wire, I bring the button with me to the finish line, and start the car from there.
I’m looking at the relay information on Wikipedia, and from what they post, the relay I’m looking for is something with similar properties to the latching relay. I then wire the charging station so that the main power goes into the control and source (I think that’s what it’s called) terminals on the relay. The source’s other terminal then leads to the fuel cell, while the push button/momentary switch goes between the source and control. When I push the button, the relay changes position, disconnects the charging station, and redirects the electricity flowing from the fuel cell into the motor.
