Classmate E11 help!!!
Was the Windows OS suppose to be pre-installed on the Classmate E11? Our Classmate came with it pre-installed, and when we are trying to run the image software it gives us a error code. We have not been able to use the flash drive that was provided to us.
Have you read the instructions?
our flash drive failed as well. we had to manually install the driver station code. if this is the case for you, there are instructions out there for that. it should be attached to this post. (we just had to do this today as well ^_^)
hope this solves your problem :slight_smile:
ClassmateE09ImagingSuplement.pdf (199 KB)
